disposalist
Mar 16, 2019Aspirant
Anyone actually have gaming prioritization working?
Has anyone actually got this working?
I play Battlefield 1 = I get no latency or jitter warnings.
I watch Netflix or YouTube on the same machine = I get some warnings.
I enable Anti-Bufferbloat...
disposalist
Mar 17, 2019Aspirant
35 views and no one has gotten it working? Or just not getting viewed by XR700 users?
I just did a test with Battlefield 1 using its network graphing function (very handy for these kind of problems) and they show that there is no difference between QoS on or off when not using Netflix (which is to expected - I just did it to see if QoS does anything weird), but with Netflix running the only difference between using QoS or not was that the latency peaks get HIGHER with QoS ON! What?...
Netduma_Jack
Mar 19, 2019NetDuma Partner
Hi there - could you follow this guide please to get QoS setup optimally: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Let us know if you're still not seeing an improvement after that. BF1 is not currently recognised automatically, so I recommend you manually add the ports to Traffic Prioritisation.
If you need help with that, please let us know.
- disposalistMar 19, 2019Aspirant
I did do all that (as I explained in my posts).
I tried with all set (anti-bufferbloat, gaming PC with majority bandwidth allocated, and specific TCP and UDP ports and ranges prioritised).
I tried with various combinations being on/off and with different amounts in bufferbloat and bandwidth allocation.
Nothing fixed the issue.
Netflix on = pulses of latency increase.
Netflix off = steady low latency.
Even tried running netflix on another PC on the network and on my phone. Using the phone app the pulses were less frequent, but still there.
- Netduma-FraserMar 19, 2019NetDuma PartnerCould you explain the physical setup you have please? E.g. ISP hub (modem mode) > XR700 (all devices) etc. Do you use IPv6 or PPPoE?
What are the ports you have added to Traffic Prioritization?
Have you entered your correct bandwidth into Anti-Bufferbloat's options? Also just confirm you haven't disabled it fully there.- disposalistMar 19, 2019Aspirant
Plusnet VDSL > Netgear DM200 in modem only mode > XR700 > gaming PC
Battlefield 1 ports added to prioritsation (as several rules): -
TCP: 5222, 9988, 17502, 20000-20100, 22990, 42127
UDP: 3659, 14000-14016, 22990-23006, 25200-25300
Corrent bandwidth entered, yes. My line is rated 80/20 but I entered 69/17 which was what was reported by DSLReports speedcheck.
I tried all three bufferbloat settings Always/When Priority/Never. Same result each time.
