dan801
Feb 21, 2021Apprentice
Anyone know if V2.3.2.114 update is safe on Xr500
I’m currently sitting on firmware **.66 and wonder if V2.3.2.114 is stable and safe to update. I’m not interested in beta testing v3 or anything and googling this firmware brings up stuff about beta t...
Netduma-Fraser
Feb 21, 2021NetDuma Partner
The pre-beta .114 just has more security updates in, it is entirely up to you whether you wish to install it or not. I can't see any reason it would cause any issues.
- dan801Feb 21, 2021ApprenticeWhy is Netgear releasing pre-beta firmware versions to general users instead of stable versions?
- Netduma-FraserFeb 21, 2021NetDuma PartnerSorry I didn't mean it that way. The beta versions are using DumaOS 3.0 whereas the stable versions - the one we're referring to is using DumaOS 2.0. So really what I meant was it's on pre-DumaOS 3.0 firmware.
