chedyus
May 31, 2020Tutor
Apex Legends on DumaOS
Hello, so i have the XR300 router, the game which I play the most is Apex Legends, I noticed in the profiles on geo filter option this game is missing, instead there is Source Engine... can i use the...
- May 31, 2020No, the profile just extends the radius size so has nothing to do with the server locations. Just put your radius to 1000km and you should be fine. The game is covered by DumaOS Classified Games so no need to add manually there.
Netduma-Fraser
May 31, 2020NetDuma Partner
The Geo-Filter profiles just adjust the radius basically based on what we think is best but you can do this yourself easily. I'd suggest the Call of Duty profile if you were to use one. We can add one in future.
- chedyusMay 31, 2020Tutor
Netduma-Fraser wrote:
The Geo-Filter profiles just adjust the radius basically based on what we think is best but you can do this yourself easily. I'd suggest the Call of Duty profile if you were to use one. We can add one in future.call of duty uses same servers locations as apex legends? for QOS the apex legends game is missing aswell instead is source engine...
- Netduma-FraserMay 31, 2020NetDuma PartnerNo, the profile just extends the radius size so has nothing to do with the server locations. Just put your radius to 1000km and you should be fine. The game is covered by DumaOS Classified Games so no need to add manually there.
ok thanks for the infos
