chedyus's avatar
chedyus
Tutor
May 31, 2020
Apex Legends on DumaOS
Hello, so i have the XR300 router, the game which I play the most is Apex Legends, I noticed in the profiles on geo filter option this game is missing, instead there is Source Engine... can i use the...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    May 31, 2020
    No, the profile just extends the radius size so has nothing to do with the server locations. Just put your radius to 1000km and you should be fine. The game is covered by DumaOS Classified Games so no need to add manually there.
