cplum75
Dec 26, 2018Aspirant
Apple TV 4th Generation - Popcorn Time
I had this cheap Verizon Fios router but I wanted to have more control over my network so I purchased the xr500. I was using popcorn time with no problem on my apple tv 4. I hooked up the xr500....an...
cplum75
Dec 27, 2018Aspirant
Hi,
I’m sorry I wasn’t clear. Popcorn time is a sideloaded app to watch movies and tv shows on the Apple TV device for streaming. My Apple TV is hardwired to the router. I figure that being I don’t Kherson popcorn time servers are, maybe it’s outside of the two filter and the traffic is being blocked. Is there anyway to disable the geofilter so I can make it a standardized router or not so restrictive to inbound connections outside of gaming?
Netduma-Fraser
Dec 29, 2018NetDuma Partner
Delete any devices that have been added on the Geo-Filter page and it won't affect it. I would also suggest disabling QoS completely in Anti-Bufferbloats options and see if that resolves your issue
- cplum75Jan 05, 2019AspirantHi, thank you for your response. I just tried that and the problem withbstreaming persist. I tried my old isp router and just a spare router thatvwas laying around. When I plug the nighhawk back up, it just spins when you select the movie.
- Netduma_JackJan 07, 2019NetDuma Partner
Random idea - could you try enabling your Guest Network >Settings >Setup >Guest Network
Then try connecting your TV to that Guest Network. Does that then solve the problem?
This workaround has fixed WiFi issues for other people with smart devices, so might work here.
