cplum75
Dec 26, 2018Aspirant
Apple TV 4th Generation - Popcorn Time
I had this cheap Verizon Fios router but I wanted to have more control over my network so I purchased the xr500. I was using popcorn time with no problem on my apple tv 4. I hooked up the xr500....an...
cplum75
Jan 05, 2019Aspirant
Hi, thank you for your response. I just tried that and the problem withbstreaming persist. I tried my old isp router and just a spare router thatvwas laying around. When I plug the nighhawk back up, it just spins when you select the movie.
Netduma_Jack
Jan 07, 2019NetDuma Partner
Random idea - could you try enabling your Guest Network >Settings >Setup >Guest Network
Then try connecting your TV to that Guest Network. Does that then solve the problem?
This workaround has fixed WiFi issues for other people with smart devices, so might work here.
