xlr8r
Feb 20, 2018Luminary
Assigning a static IP address to home devices
hi folks, this is my first post. i havent received my XR500 just as yet (as i live in the UK - but is due 1st March via Amazon pre-order). I have watched a few youtube videos yet Im still not...
- Feb 20, 2018No benefit I can see, I'd just let DHCP handle the rest of the devices that you don't care about giving a static IP to.
Netduma-Fraser
Feb 20, 2018NetDuma Partner
Hi xlr8r, great to hear you're getting the XR500. You can set this in Settings > LAN Setup, then click Add under Address reservation. Then you can select the devices you want and give them a static IP. I've included a screenshot >
xlr8r
aha! perfect thanks.
so, effectively I would need to keep all my home devices DISCONNECTED first, assign the static IP's and then turn everything on to get assigned correctly ?
thanks
- Netduma-FraserFeb 20, 2018NetDuma PartnerYou need to connect them first. Then set the IPs, the devices will reconnect once you apply and then should have the new IP you have set.
- xlr8rFeb 20, 2018Luminary
excellent!
moving from the R7000 dd-wrt, i currently have my static ip ranges setup "outside" the DHCP range, On the XR500 is there any benefit to doing things that way ? or should I just let the router do its thing if i set the dhcp range to the full 254 available ?
- Netduma-FraserFeb 20, 2018NetDuma PartnerNo benefit I can see, I'd just let DHCP handle the rest of the devices that you don't care about giving a static IP to.
