xlr8r
Feb 20, 2018Luminary
Assigning a static IP address to home devices
hi folks, this is my first post. i havent received my XR500 just as yet (as i live in the UK - but is due 1st March via Amazon pre-order). I have watched a few youtube videos yet Im still not...
- Feb 20, 2018No benefit I can see, I'd just let DHCP handle the rest of the devices that you don't care about giving a static IP to.
Netduma-Fraser
Feb 20, 2018NetDuma Partner
You need to connect them first. Then set the IPs, the devices will reconnect once you apply and then should have the new IP you have set.
xlr8r
excellent!
moving from the R7000 dd-wrt, i currently have my static ip ranges setup "outside" the DHCP range, On the XR500 is there any benefit to doing things that way ? or should I just let the router do its thing if i set the dhcp range to the full 254 available ?
- Netduma-FraserFeb 20, 2018NetDuma PartnerNo benefit I can see, I'd just let DHCP handle the rest of the devices that you don't care about giving a static IP to.
- xlr8rFeb 20, 2018Luminary
brilliant many thanks
...i still cant remember why i did it that way in te first place .... ?
many thanks for your help !
