Rx700codmaster
Nov 30, 2018Guide
Asus rt66 to xr700 upgrade- what to expect
Upgrading from an older asus rt66n router. What to expect and the transition. Im expecting alot of difference and reading alot about the nighthawk. We plan on streaming movies along with game play...
Nov 30, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
- Rx700codmasterNov 30, 2018GuideThe modem is supplied by the ISP, no known config is available by end user.
All utility mods will be accomplished onsite by end user.- Netduma_JackNov 30, 2018NetDuma Partner
I work from Netduma, so I can help answer any questions you have about DumaOS, our router operating system that runs on the Nighthawk XR500 and XR700.
But first of all, I recommend you go to this webpage to learn more about our features. It will only take 1-2 minutes to read: https://netduma.com/features/
We also have a massive roadmap of new features coming out, so it'll only improve your router!
- Rx700codmasterNov 30, 2018GuideIm a little skeptical about having shelled out 500 bucks for a router. I consider it the quiessential device that allows for all data exchanges for our home network. We needed an upgrade but such a leap of faith?
Our current device is the Asus rt66n. It has worked well for years. Replacing it is not mandatory but more of an enhancement.
I read a bunch of the reviews on Amazon but then realized most were for the XR500. Of the 258 reviews written, only 7 were for the XR700.
