SouthernGypsy
Jun 12, 2024Apprentice
Automatic Latency Reduction Program Location?
When I was first setting up my XR1000v2 I remember it going through a rutine where it said it was going to test my initial latency/ping rates and perform tests and make adjustments to automatically improve it. Which it went through a rutine and then said it had optimized the settings resulting in a lowered ping rate.
I can't find where to go to re-perform that. All I found was the "Auto-Setup" under the QoS congestion control menu but that does not look like what it did before. The test I am reffering to had nothing to do with QoS but rather the overall initial latency....
Does anyone know where the option is to re-perform that latency reduction rutine? (without having to reset the entire router as all my other settings are good).
1 Reply
- Netduma-FraserNetDuma PartnerThat is what the Auto Setup does, that's how you do it without doing a factory reset to do it the way you saw before
