DonnyPes's avatar
DonnyPes
Follower
Jul 17, 2021
bad experience , still having huge lag
I bought a xr300 router hoping to improve online experience in epes2021. The game its no longer in the prioritization list. The game its P2P and having a lot lag. Connection it's 90 with 90 Mbps, on pc wired. Any suggestions would be very very helpful. thanks
1 Reply
  • Sorry to hear this, I believe you should still be able to filter this game in Geo-filter, if you set you radius to be over your local area are you able to find a game?
    Are you using QoS? If not, I'd suggest configuring this as it can help a lot with local congestion.
