Mygamertagsucks
Dec 08, 2021Apprentice
Bandwidth Allocation Issues After Firmware Update
Hey everyone, Since I updated my XR500s firmware, I keep having an issue with QoS settings. After I updated the firmware, I performed a factory reset by inserting a paper clip into the factory reset ...
Netduma-Liam
Dec 09, 2021NetDuma Partner
Are you clicking 'Update bandwidth' after changing the sliders? Otherwise, these changes won't stick.
Let me know if that's the case.
Mygamertagsucks
Dec 09, 2021Apprentice
Thank you for the reply.
Yes, I am clicking "Update Allocation" as well as "Save" on the box that opens up on the right side where you can slide the percentage up and down. I normally go to the PS4, use the slider to set my bandwidth to 15Mbps, which is roughly 90% of the upload. I click"Save" on the slider box, and "Update Settings" on the little flower page on the left. Then I do the same thing with the download settings. It never changes unless I check the Geo-Filter. There's nothing connecting to the network while I'm trying to play the PS4, so I'm not sure why the settings keep getting reset.
- Netduma-FraserDec 10, 2021NetDuma PartnerI can't reproduce the issue you're having but if you're using devices instead of applications then come back to the page the view will default to applications. What web browser/device are you using to change the settings? Also you don't really need to give it that much bandwidth, it will use at most 1Mbps.
- MygamertagsucksJan 01, 2022ApprenticeThanks again, for the continued replies. And, I'm sorry, again, for the delay. I get about one week a month I can game.
I'm running Windows 11, and opening the router login page via Chrome, but it does the same thing when I open it with Firefox.- Netduma-FraserJan 02, 2022NetDuma PartnerNo worries, if it's not too much trouble would you be able to record a little video of how you're setting it and then showing it reverting? That would be the best way for me to see what is happening.
