Mygamertagsucks
Dec 08, 2021Apprentice
Bandwidth Allocation Issues After Firmware Update
Hey everyone, Since I updated my XR500s firmware, I keep having an issue with QoS settings. After I updated the firmware, I performed a factory reset by inserting a paper clip into the factory reset ...
Mygamertagsucks
Dec 09, 2021Apprentice
Thank you for the reply.
Yes, I am clicking "Update Allocation" as well as "Save" on the box that opens up on the right side where you can slide the percentage up and down. I normally go to the PS4, use the slider to set my bandwidth to 15Mbps, which is roughly 90% of the upload. I click"Save" on the slider box, and "Update Settings" on the little flower page on the left. Then I do the same thing with the download settings. It never changes unless I check the Geo-Filter. There's nothing connecting to the network while I'm trying to play the PS4, so I'm not sure why the settings keep getting reset.
Netduma-Fraser
Dec 10, 2021NetDuma Partner
I can't reproduce the issue you're having but if you're using devices instead of applications then come back to the page the view will default to applications. What web browser/device are you using to change the settings? Also you don't really need to give it that much bandwidth, it will use at most 1Mbps.
- MygamertagsucksJan 01, 2022ApprenticeThanks again, for the continued replies. And, I'm sorry, again, for the delay. I get about one week a month I can game.
I'm running Windows 11, and opening the router login page via Chrome, but it does the same thing when I open it with Firefox.- Netduma-FraserJan 02, 2022NetDuma PartnerNo worries, if it's not too much trouble would you be able to record a little video of how you're setting it and then showing it reverting? That would be the best way for me to see what is happening.
- MygamertagsucksJan 02, 2022ApprenticeI will absolutely grab a little video to show what's happening. I know I am not describing this very well.
