KC777
Nov 12, 2018Aspirant
Before buying NETGEAR Nighthawk Pro Gaming XR700 WiFi Router
I wanted to know if the NETGEAR Nighthawk Pro Gaming XR700 WiFi Router will work with Amazon's Alexa or if not, any plans to do so with an update in the future?
Nov 13, 2018Guru - Experienced User
I suggest finding a good place with a refund policy, lilke Amazon or local store like best buy or Frys. Get one here and if it doesn't work do your liking, you can return it.
KC777
Nov 13, 2018Aspirant
Some of Netgear's other routers work with Alexa, so I would think it would not be a very big deal to do a firmware upgrade with XR700 to let it work with Alexa as they already have the code, programming, and firmware with other Netgear routers. For sure, I would buy at Amazon with there easy to return and ship. But this is 500 bucks, so I wanted to find out about my question.
