TrebleTA
Sep 03, 2021Initiate
Before i buy XR500
Hi all and thanks inadvance. I'm looking to get the XR500, my ISP is sky and i want to replace there er110 sky hub. has the XR500 got a modem capable of connecting to there mer, I sure I've seen it ...
Netduma-Fraser
Sep 05, 2021NetDuma Partner
It can handle MER as it has the Option 60/61 identifier settings where you can enter that in. The hub is RJ11 as it's a modem/router and therefore made to take the connection from the wall. You may need to look online to see whether other people have had success bypassing the hub.
- TrebleTASep 05, 2021InitiateThanks for the replys it's not what I'm after, I dont want 2 devices running. So need a dsl modem router combo. I dont think netgear make any.
