TrebleTA
Sep 03, 2021Initiate
Before i buy XR500
Hi all and thanks inadvance. I'm looking to get the XR500, my ISP is sky and i want to replace there er110 sky hub. has the XR500 got a modem capable of connecting to there mer, I sure I've seen it ...
Netduma-Fraser
Sep 05, 2021NetDuma Partner
It can handle MER as it has the Option 60/61 identifier settings where you can enter that in. The hub is RJ11 as it's a modem/router and therefore made to take the connection from the wall. You may need to look online to see whether other people have had success bypassing the hub.
TrebleTA
Sep 05, 2021Initiate
Thanks for the replys it's not what I'm after, I dont want 2 devices running. So need a dsl modem router combo. I dont think netgear make any.
