Shikwan68's avatar
Mar 26, 2019
Benefits of LAG
I have the XR700 router connected via LAG to a Netgear ProSwitch GS110TP which also supports LAG. I have a USB Hdd connected to router and my WIRED devices are connected to the ProSwitch. Questi...
  • Netduma-Fraser's avatar
    Mar 26, 2019
    In your scenario I believe the benefits will just be with the USB HDD performance. None of the other things you mentioned will be improved.
