RichardRO
Dec 06, 2020Aspirant
Best cable modem for XR1000
I would like to know if a CM2000 would be a good match for my XR1000. Or if I should choose a different model. My ISP is Spectrum Los Angeles. Thank you.
Dec 06, 2020Guru - Experienced User
NGs CM1000 would be best since the XR1000 doesn't support a 2.5Gb WAN port or support LAG, which the CM200 support a 2.5Gb WAN port. A CM1100 would be good however this modem support LAG. So the CM1000 would be best fit. First contact your ISP to ensure what modems are supported by your ISP.
RichardRO
Thank you for the reply. Do you think it would make a difference in gaming compared to the cable modem provided by my ISP? Are there any special features that would help the routing or increase the transfer?
- FURRYe38Dec 07, 2020Guru - Experienced User
Getting a stand alone modem with out any built in router or wifi would be recommended.
