bacevedo
Oct 12, 2018NETGEAR Employee Retired
Best Call of Duty Black Ops 4 Optimization with the XR500
Call of Duty: Black Ops 4
Hey Nighthawks,
It's finally here! Black Ops 4 and the NPG team has a few tips and tricks to get the best possible ping and help get you the highest K...
Stevecook
Nov 15, 2018Apprentice
I have an xr500 and seems like so many issues with bo4. One game will be playing on dedicated server with 20 ms ping. Next game the server not shown on map and I'm playing on peer with 120 ms ping. But the peer I'm playing on is not shown inside of with circle of geo filter. I delete console from geo filter and flush cloud. Turn ps4 back on and play on dedicated server couple games then back to same thing. I'm in MD on east coast so no reason I shouldn't have an issue playing on a dedicated server as your map shows several around me but on my heofilter map they do not show up.
- bacevedoNov 15, 2018NETGEAR Employee Retired
There has been some issues with the CoD servers on the Activision side probably due to the overwhelming amount of players that have started playing.
You still should be able to geo-filter to get connected to the nearest server.
- StevecookNov 16, 2018ApprenticeThe server dissappers and no longer shows on geo filter Map. If I do what you guys said by removing the device and flush cloud and readd device it shows up but then does same thing again. I have keep doing this process over and over after playing for a little bit
- Netduma-FraserNov 16, 2018NetDuma PartnerWhen does it start happening again after you did that workaround?
