bacevedo
Oct 12, 2018NETGEAR Employee Retired
Best Call of Duty Black Ops 4 Optimization with the XR500
Call of Duty: Black Ops 4
Hey Nighthawks,
It's finally here! Black Ops 4 and the NPG team has a few tips and tricks to get the best possible ping and help get you the highest K...
bacevedo
Nov 15, 2018NETGEAR Employee Retired
There has been some issues with the CoD servers on the Activision side probably due to the overwhelming amount of players that have started playing.
You still should be able to geo-filter to get connected to the nearest server.
Stevecook
Nov 16, 2018Apprentice
The server dissappers and no longer shows on geo filter Map. If I do what you guys said by removing the device and flush cloud and readd device it shows up but then does same thing again. I have keep doing this process over and over after playing for a little bit
- Netduma-FraserNov 16, 2018NetDuma PartnerWhen does it start happening again after you did that workaround?
