Hakanx
Oct 19, 2022Follower
Best Gaming Router recommendation
Hello. What is your recommendation for the best router for online gaming? It is important for me that it supports multiple devices. Would you recommend the NETGEAR N600 Dual Band WiFi Router? Does it...
Oct 19, 2022Guru - Experienced User
I'd never recommend something 2 generations behind (n600) for gaming.
How big is your home?
What speeds do you pay for?
Are you gaming over wifi or ethernet?
What console/device are you gaming on?
What's your budget?
those are all kind of key questions. Its easy to recommend "the best gaming router" if there isn't a budget because there's some pretty expensive gaming routers out there. Its more challenging when you get specific to what you need for your home.
