Sur_justin
Oct 12, 2018Aspirant
Best settings for xbox one and xr450
So I recently just bought the nighthawk xr450 and I only have an Xbox one to game. I need help knowing what settings to run!!!!! I have at&t u-verse as my ISP but I always come up with a double bat or...
Oct 12, 2018Guru - Experienced User
What FW is currently loaded?
Wired connection between the router and xbox is preferred.
Disable "Instant ON" feature on the xbox.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Set WPA2 and AES only for wifi security.
Disable IPv6, MIMO(if you don't have any MIMO supporting devices) and 160HT on the router.
Review this as well:
http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide
Sur_justin
model number of ISP modem is 5268ACFXN not sure what mfr is though
Firmware is 2.3.2.32
- Netduma_JackOct 13, 2018NetDuma Partner
I recommend you read the DumaOS Optimal Settings guides. They include how to get an open NAT and how to setup Geo-Filter and QoS to get the best ping:
http://support.netduma.com/support/solutions/folders/16000090646
- FURRYe38Oct 13, 2018Guru - Experienced User
Your ISP modem I believe has a router already built in:
Modem Combo Units:
Couple of options,
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
