diehardbattery1
Feb 05, 2018Guide
Best way to reduce lag on LAN?
So I have the XR500, and a gs108 switch. Currently I have the Xbox One and my PC connected to the switch as well as other stuff. Everything is Gigabit. When I stream my Xbox to my PC, I occassional...
diehardbattery1
Feb 06, 2018Guide
wrote:
I was referring to if it was enabled at the time that it could be QoS'd twice. The settings I gave should resolve the issue.
Your suggestions did in fact make an improvement. I am still seeing a bit of lag but not like before. I've only used it for a short time but so far so good. Now I am wondering if thesettings can be ajusted can further? Tweaked a bit maybe?
Netduma-Fraser
Feb 07, 2018NetDuma Partner
Great to hear that. Yes you could give your devices more bandwidth, higher or lower Anti-Bufferbloat - it depends on your connection. There will be a sweet spot, my settings are just a starting point. Make sure the Geo-Filter isn't active in Filtering Mode, that might affect the stream.
- diehardbattery1Feb 07, 2018Guide
wrote:
Great to hear that. Yes you could give your devices more bandwidth, higher or lower Anti-Bufferbloat - it depends on your connection. There will be a sweet spot, my settings are just a starting point. Make sure the Geo-Filter isn't active in Filtering Mode, that might affect the stream.Can you elaborate on the relationship between giving more bandwidth and anti bufferbloat? I have an AT&T Fiber 1GB connection if that helps.
Also I would prefer to keep the Geo Filter Enabled. Would spectating mode be better? The reason I ask is that I usually stream COD WW2 and would like to have the best connection possible, hence the Geofilter.
- Netduma-FraserFeb 07, 2018NetDuma PartnerThe lower the percentage the more room you allow for devices & their applications to use the internet at the same time and vice versa. 70/70 is a good compromise. Considering you've got such a high bandwidth and still experiencing a little bit of lag, I'm thinking theres something else affecting it. Perhaps a cap on the speed of the xbox's ethernet port. I don't think this is a router issue but just in case disable QoS completely in Anti-Bufferbloat's options. If its the same then likely a problem elsewhere.
- diehardbattery1Feb 08, 2018Guide
Okay, I'll do that but I must be missing something here... What does an internet speed test have to do with what I am experiencing on a LAN which, doesn't use internet at all?
http://www.dslreports.com/speedtest/29488597
- FURRYe38Feb 08, 2018Guru - Experienced User
So have you removed all swtiches from the router and directly connected your gaming devices to the router and or PC's to the router to see if you experience LAG issues.
I would disable all non essential devices to help weed out any other devices that maybe causing problems.
I have 99% sent on both sliders and Detect only on Priority traffic. Two xbox one consoles are set to balance Up and Down bandwith since I have two consoles that game sometimes at the same time. IPv6 is disabled since my ISP doesn't support IPv6 natively. NAT Filter set to OPEN for OPEN NAT on console dash board and in same game running on both consoles at the same time.
Do seem to see any lag unless it's coming from out side my network or gaming with others.
If you feel that LAG continues, then I would try another router and see if it continues. Possible faulty router.
wrote:Okay, I'll do that but I must be missing something here... What does an internet speed test have to do with what I am experiencing on a LAN which, doesn't use internet at all?
- Netduma-FraserFeb 08, 2018NetDuma PartnerIf both are connected directly to the XR500 via ethernet cable it's impossible for it to be getting lag when they're just communicating with each other. Disable QoS completely from Anti-Bufferbloat's menu and try again if you still encounter issues.
- schumakuFeb 08, 2018Guru - Experienced User
Netduma-Fraser wrote:
If both are connected directly to the XR500 via ethernet cable it's impossible for it to be getting lag when they're just communicating with each other.The very same if the Windows and the Xbox are connected to the same GbE switch Ian, isn't it ?
Even if one would be connected to one of the XR500 ports, the switch on another port on the XR500 switch, and the other end to the switch - there is still nothing which can create a serious lag.
