diehardbattery1
Feb 05, 2018Guide
Best way to reduce lag on LAN?
So I have the XR500, and a gs108 switch. Currently I have the Xbox One and my PC connected to the switch as well as other stuff. Everything is Gigabit. When I stream my Xbox to my PC, I occassional...
Feb 09, 2018Guru - Experienced User
I would disconnect or turn OFF all other devices as much as you can accept for the xbox and game. See if you notice any lag. Directly connect your game console to the router. Don't use a switch.
If your experiencing LAG while other devices are online and you don't when everything else is off, then one of these devices is probably the culprit. You'll need to graduate turning on each device to see when and where the LAG starts. One thing to look at if you have a switch that has LED indicators is to see if the switch LED actifivity is constantly ON and blicking when you feel that nothing else is going on, or not gaming or streaming anything. If this is happening, then one of the devices is doing something it shouldn't be.
Seems like this is not a router issue.
Netduma-Fraser
Feb 12, 2018NetDuma Partner
Hi diehard, I just wanted to check in and see how you're getting on. Is this still an issue you're having?
- diehardbattery1Feb 12, 2018Guide
wrote:
Hi diehard, I just wanted to check in and see how you're getting on. Is this still an issue you're having?So far so good. I still see an occasional hiccup but nothing like before. I have encountered another issue regarding party chat though. Should I mention that here or start a new thread?
- Netduma-FraserFeb 13, 2018NetDuma PartnerGreat to hear that. I believe I know what you're talking about, we have a hot fix firmware available for that today so once it's been tested I'll send it to you later today.
- diehardbattery1Feb 13, 2018Guide
Okay, I did see mention of it on the Netduma forum. I'm not sure if my issue completely applies to that but I guess the hotfix is worth a shot. How are you going to send the hotfix? Is it just a regular firmware update or so you need my email address?
