diehardbattery1
Feb 05, 2018Guide
Best way to reduce lag on LAN?
So I have the XR500, and a gs108 switch. Currently I have the Xbox One and my PC connected to the switch as well as other stuff. Everything is Gigabit. When I stream my Xbox to my PC, I occassional...
diehardbattery1
Feb 13, 2018Guide
Okay, I did see mention of it on the Netduma forum. I'm not sure if my issue completely applies to that but I guess the hotfix is worth a shot. How are you going to send the hotfix? Is it just a regular firmware update or so you need my email address?
Netduma-Fraser
Feb 13, 2018NetDuma Partner
Its a regular firmware update so I'll send you the link in a PM on here or I can email it, whatever you prefer. If you want me to email it just send me your email in a PM.
- diehardbattery1Feb 13, 2018Guide
A PM with the link will work. Thanks!
