UK_Wildcats
Jun 10, 2020Apprentice
Beta Forum
What happened to the beta forum access? I used to have to have access, and now access is denied.
Belbs
Jun 15, 2020Aspirant
Access denied on beta forum.
Can anyone help me?
Thank you
Can anyone help me?
Thank you
- Netduma-FraserJun 16, 2020NetDuma PartnerRick6922 it will be quite soon, there won't be long between each router beta.
Belbs just to check, have you received an invite for the XR500 beta to your email?- Rick6922Jun 16, 2020Luminary
ok tks.
- BelbsJun 17, 2020AspirantWhen I signed up I put my Netduma forum username and I noticed other people doing the same mistake so I quickly made a Netgear account with the same username “belbs”. I wanted to make sure that my sign up is still ok and are you able to check if I will be getting my invite soon or what wave I will be getting it?
Thank you- Netduma-FraserJun 17, 2020NetDuma PartnerBelbs I'm not sure if we can tell you which wave you'll be on but ChristineT will be able to let you know if your sign up is okay and that information if possible.
