UK_Wildcats
Jun 11, 2020Apprentice
Beta Forum
What happened to the beta forum access? I used to have to have access, and now access is denied.
Belbs
Jun 17, 2020Aspirant
When I signed up I put my Netduma forum username and I noticed other people doing the same mistake so I quickly made a Netgear account with the same username “belbs”. I wanted to make sure that my sign up is still ok and are you able to check if I will be getting my invite soon or what wave I will be getting it?
Thank you
Thank you
ChristineT
Jun 17, 2020NETGEAR Employee Retired
Hello Belbs ,
Thanks for sharing your experience! Please check your ability to access the Beta forum now and let me know if you are still unable to access the forum.
Cheers,
Christine
