usermac
Sep 15, 2018Luminary
Black Ops 4 PORT FORWARD strict nat
Usually I can open my nat but looking at the xr500 portforwarding looks really confusing compaired to my old simplified bt smart hub
Anyways I am playing the Black ops 4 beta and can see my nat is ...
- Sep 17, 2018
The guide did not help me as I am useing a Gaming pc ....
However I did manage to solve the problem but found some service name confusion.
What I did was go into portforwarfing add custom service on the XR500 set the service name as black ops 4 pc set UDP TO 3074
and then went into modem dm200 portforwarding add custom service and the service name apeared as Black↔ops↔4↔ and just repeat UDP 3074 AND LINK IT TO THE XR500 IP. Once you click apply or add then the service name in the modem will just show up as the same as the XR500 in my case I chose Black ops 4 pc
And now my nat is open.
I took a screen shot of both modem and routor if that helps anyone with same issue.
Netduma_Jack
Sep 16, 2018NetDuma Partner
Could you follow this guide please Mac - should all be sorted for you once you have followed that:
http://support.netduma.com/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-nat
usermac
Sep 17, 2018Luminary
Thanks for the handy guide Jack
will give this a go and report back.
- usermacSep 17, 2018Luminary
- FURRYe38Sep 17, 2018Guru - Experienced User
FYI Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the NG router in Router mode.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Thanks Fury only the reason I am not useing the modem in bridge mode is because I am unable to monitor my modem stats via the XR500. Basic things are missing like my noise margin/sync speed etc. I did ask for this feature to be added and the devs of this routor on there live stream said they would add it at some point.
I have ADSL and find it very helpful to see what is going on with my connection and being able to see line stats can identify line faults errors etc.
The modem I use is a Netgear DM200 and seems to work very well with the Nighthawk because before my old BT Smarthub would drop connection every other day but this modem holds.
