usermac's avatar
usermac
Luminary
Sep 15, 2018
Black Ops 4 PORT FORWARD strict nat
Usually I can open my nat but looking at the xr500 portforwarding looks really confusing compaired to my old simplified bt smart hub Anyways I am playing the Black ops 4 beta and can see my nat is ...
  • usermac's avatar
    usermac
    Sep 17, 2018
    The guide did not help me as I am useing a Gaming pc ....
    However I did manage to solve the problem but found some service name confusion.
    What I did was go into portforwarfing add custom service on the XR500 set the service name as black ops 4 pc set UDP TO 3074
    and then went into modem dm200 portforwarding add custom service and the service name apeared as Black↔ops↔4↔  and just repeat UDP 3074 AND LINK IT TO THE XR500 IP. Once you click apply or add then the service name in the modem will just show up as the same as the XR500 in my case I chose Black ops 4 pc
    And now my nat is open.
    I took a screen shot of both modem and routor if that helps anyone with same issue.
