Consumer0129383
Oct 26, 2019Luminary
Black Ops 4 PS4 Pro Lan disconnecting XR500
I am randomly getting kick out of games due to a "Lan not connected" message when it is clearly connected. It boots me from the game and almost instantly I am able to join another game no problem. ...
- Nov 12, 2019
How can I get a refund from netgear for this router?
Netduma-Fraser
Nov 12, 2019NetDuma Partner
The Chicago one inside your radius was a server so it is working successfully. The game will try to connect you to whatever it can, that's when the Geo-Filter kicks in and reports what it's doing and prevents it. You won't always see the available servers within the radius until the game tries to connect you to one because we've forced it to.
Consumer0129383
Nov 12, 2019Luminary
- Netduma-FraserNov 12, 2019NetDuma PartnerIt sounds like it is working as it should be by getting you servers within your parameters. I'd recommend you have a look through our optimal settings guides so you can setup correctly and get to know the router: http://support.netduma.com/en/support/solutions/folders/16000090646
If you still want to return it you'd need to go through the retailer you purchased with. You could create a ticket with Netgear here and they'll help: http://support.netgear.com/ - Consumer0129383Nov 12, 2019Luminary
I've had it too long. But, I have read through most of these forums and I have done every step that has been recommended to do. I have setup "correctly" and it doesn't seem to help my situation i.e, lagging, lan disconnects, and some other issues. It's really aggrevating to spend this much money and it doesn't seem to do what it was supposed to.
- Netduma-FraserNov 12, 2019NetDuma PartnerYou're with Google Fiber so QoS isn't really needed for you - assuming you're on a 1gbps line. However, if that's not working for you then it would be worth trying it with QoS as it could only help. Forcing different servers that are slightly further away can actually improve gameplay ironically so would suggest that if the servers you usually play on aren't as good.
- Consumer0129383Dec 04, 2019Luminary
Still connecting to denied servers in Black Ops 4 on my PS4 Pro. Why is this? Why doesn't this router work as advertised?
- Netduma-FraserDec 04, 2019NetDuma PartnerAre you certain they're exactly the same and not just in the same location? Do they have the same IDs or names that you've given them? Did you try to block servers that had white solid circles around them? If so they can't be blocked as they're required for online play.
Are you certain they're exactly the same and not just in the same location? Yes.
Do they have the same IDs or names that you've given them? Yes.
Did you try to block servers that had white solid circles around them? No, the servers that I block are typically labeled "Peer".
- Netduma-FraserDec 04, 2019NetDuma PartnerOkay thanks for the information, if you find one that shows up as a server could you try to block that and see if it works correctly?
Find what? This isn't clear to me. Every time I've connected today it's been to a "Peer" server that I have labeled and denied. So, I am unsure what you mean by "if you find one that shows up as a server could you try to block that and see if it works correctly?"
Banned this one awhile back connected to it right now!
- Netduma-FraserDec 04, 2019NetDuma PartnerOn the Geo-Filter if when you get a game it has a server icon on the map/says dedicated instead of peer on the ping panel could you try blocking it and see if it works as opposed to the peer ones you've had so far.
I have blocked a few labeled "dedicated" and once deny I've never reconnected to one.
- Netduma-FraserDec 04, 2019NetDuma PartnerOkay thanks for that information then, this should be resolved when we do a cloud update to rectify the misclassified servers but I will let the team know so they can get that done sooner.
- Consumer0129383Dec 09, 2019Luminary
Yeah, I'd Like to find out how to get my money back. I am seriously unhappy with this router. NONE of the features work as advertised. So, now the dedicated servers that I have blocked are being allowed as you can see from the picture.
- Netduma_AlexDec 10, 2019NetDuma Partner
Were you on Filtering Mode when this screenshot was taken?
