Tkbuc
Mar 01, 2024Guide
Blinking Red/Green Light for Globe Icon
For the past two days, when I wake up in the morning and go into my home office, the globe icon on my XR1000 is flashing Red/Green. The internet and wifi is working with great upload and download sp...
Netduma-Fraser
Mar 01, 2024NetDuma Partner
It's absolutely normal based on this: https://kb.netgear.com/24244/What-do-the-LEDs-on-my-NETGEAR-router-mean likely because you notice it first thing in the morning there isn't any traffic which is why it isn't blinking white at that time
Tkbuc
Mar 01, 2024Guide
Netduma-Fraser but the internet LED was blinking red/green. That is not listed in that link you provided.
- TkbucMar 01, 2024Guide
Is it safe to download the latest firmware (Firmware Version 1.0.0.72 - Hot Fix) that was released on 2/20/24?
- FURRYe38Mar 01, 2024Guru - Experienced User
If you have the V1 variant of the XR1000, yes, give it a go.
I'd do a full on factory reset and setup from scratch after the router processes the FW. I'd also power OFF the iSP modem for 1 minute then back ON, then complete the setup wizard. - Netduma-FraserMar 01, 2024NetDuma PartnerYes it's safe, it's just a security update. In System Information it will tell you if you're on V2
All v1 XR1000s run FW v1.0.x
All v2 XR1000s run FW v1.1.x
Thank you both for all your help!
