Tkbuc
Mar 01, 2024Guide
Blinking Red/Green Light for Globe Icon
For the past two days, when I wake up in the morning and go into my home office, the globe icon on my XR1000 is flashing Red/Green. The internet and wifi is working with great upload and download sp...
Tkbuc
Mar 01, 2024Guide
Netduma-Fraser but the internet LED was blinking red/green. That is not listed in that link you provided.
Tkbuc
Mar 01, 2024Guide
Is it safe to download the latest firmware (Firmware Version 1.0.0.72 - Hot Fix) that was released on 2/20/24?
- FURRYe38Mar 01, 2024Guru - Experienced User
If you have the V1 variant of the XR1000, yes, give it a go.
I'd do a full on factory reset and setup from scratch after the router processes the FW. I'd also power OFF the iSP modem for 1 minute then back ON, then complete the setup wizard. - Netduma-FraserMar 01, 2024NetDuma PartnerYes it's safe, it's just a security update. In System Information it will tell you if you're on V2
All v1 XR1000s run FW v1.0.x
All v2 XR1000s run FW v1.1.x
- TkbucMar 01, 2024Guide
Thank you both for all your help!
