MThabault
Dec 14, 2024Aspirant
Blocked telemetry system
I upgraded my modem routers from the ISP providers standard gear. Before I had the ISP provider modem attached to a UeeVii wireless bridge to an apartment that had a Netgear splitter and the apartme...
- Dec 15, 2024
It might be necessary to perform a new setup on the septic system.
Because each router creates a unique LAN subnet, the IP addresses assigned by this new XR1000 router will be different from the IP addresses assigned by the original XR1000 router.
Ordinarily, we expect computer devices to adapt to changing networks by issuing a new DHCP request ("tell me what IP to use and where the gateway is") If the septic system has been on line all this time, perhaps it is continuing to use the previous network assignment and is looking for a gateway IP that it can no longer reach.
Before rushing off and resetting the septic system, it might be worth taking a minute to decide how you intend to deal with having "two routers". i.e. do an internet search on "Double NAT problems". Most users would rather avoid potential problems in the future by running that second XR1000 in Access Point (AP) mode, which might mean that the septic system will suddenly work again.
Netduma-Fraser
Dec 15, 2024NetDuma Partner
Good advice above, however could you disable Adblocker on the router and then check again please?
CrimpOn
Dec 15, 2024Guru - Experienced User
I do not see the word "blocker" in the XR1000 User Manual. How does the user control it?
- Netduma-FraserDec 15, 2024NetDuma PartnerIf you look on the interface you'll see the Adblocker page on the left, go to it and just click disable
- CrimpOnDec 15, 2024Guru - Experienced User
Which interface? (Netgear 'app' or the XR1000 web interface?)
(I should know by now that Netgear User Manuals and Product Data Sheets are a "work not in progress".)
- Netduma-FraserDec 16, 2024NetDuma PartnerThe web interface
