MThabault
Dec 14, 2024Aspirant
Blocked telemetry system
I upgraded my modem routers from the ISP providers standard gear. Before I had the ISP provider modem attached to a UeeVii wireless bridge to an apartment that had a Netgear splitter and the apartme...
- Dec 15, 2024
It might be necessary to perform a new setup on the septic system.
Because each router creates a unique LAN subnet, the IP addresses assigned by this new XR1000 router will be different from the IP addresses assigned by the original XR1000 router.
Ordinarily, we expect computer devices to adapt to changing networks by issuing a new DHCP request ("tell me what IP to use and where the gateway is") If the septic system has been on line all this time, perhaps it is continuing to use the previous network assignment and is looking for a gateway IP that it can no longer reach.
Before rushing off and resetting the septic system, it might be worth taking a minute to decide how you intend to deal with having "two routers". i.e. do an internet search on "Double NAT problems". Most users would rather avoid potential problems in the future by running that second XR1000 in Access Point (AP) mode, which might mean that the septic system will suddenly work again.
CrimpOn
Dec 15, 2024Guru - Experienced User
MThabault
Dec 17, 2024Aspirant
Sorry for the delay but it took me awhile to execute. It appears the double NAT issue was the problem. Although I did power down the transmitter and re-powered it up as well. We put the downstream router in AP mode. There does not appear to be any loss of functionality as a result of speed etc and the telemetry now is working. Thanks to all for the help.
- Netduma-FraserDec 17, 2024NetDuma PartnerThat's great to hear, thanks for the update and posting your solution as well.
- FURRYe38Dec 17, 2024Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
