Raith13
Sep 28, 2019Aspirant
Boot loop after firmware upgrade
After doing a firmware upgrade within the DumaOS page the router is now stuck in a perpetual boot loop. Nothing on it works. Help!
Sep 28, 2019Guru - Experienced User
How wast he FW updated? With a wireless or wired PC? Wired is always preferred.
What browser did you use to do the upgrade? FF or Opera is preferred.
Try this and see if you can get the XR recovered:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
First try Windows 7/10 built in TFTP program.
Raith13 wrote:After doing a firmware upgrade within the DumaOS page the router is now stuck in a perpetual boot loop. Nothing on it works. Help!
- Raith13Sep 29, 2019Aspirant
Hi, I tried this. It gets through the "PUT" step, the power LED goes solid white and nothing else happens. I left it for 6 hours without anything happening. I then restarted the router only to be greeted with the same blinking white LED. I then tried the same process with an older version of firmware and got the same result.
