sqb
Aug 09, 2019Aspirant
Bridge Mode in XR700
Hello. I have two routers XR700 and I want to connect them with each other via 802.11ad. So I tried to set the bridge mode on the one of them according it: https://kb.netgear.com/24105/What-is-bri...
Aug 09, 2019Guru - Experienced User
Even if you could get this working, why would you want to connect them via the wireless AD? Its effective range is 30 ft and struggles with any obstacles in the way. Its basically good for same room usage for high bandwidth applications.
https://arstechnica.com/gadgets/2016/12/802-11ad-wifi-guide-review/
