ExtraYANKEE23's avatar
Jul 08, 2021
Bridging My Cable Modem + Router w/ Nightgear Router
So I bought a Netgear Nighthawk XR500 and bought a Arris Surfboard SB8300 and wanted to know how to bridge these properly cause I’m always lagging out of my games and want to have the fastest connection I can have.
    • ExtraYANKEE23's avatar
      ExtraYANKEE23
      Tutor
      Yea when I log into it there’s a option to turn on bridge mode but don’t have any experience doing it so wanted to see if someone could help me out
  • plemans's avatar
    There's an SB8200 and a SBG8300
    SB8200 which is a modem only
    SBG8300 is a modem router combo device
    which one do you have?
      • plemans's avatar
        If you enable bridge mode on the SBG8300, it puts it in modem only mode.
        So enable that, disconnect everything hardwired from the SBG (it'll reboot itself) and once it reboots, power it off. Then connect your netgear router to lan port 1 on the sbg and have the netgear turned off.
        Boot up sbg and give it a couple minutes.
        Then boot up the netgear and try setup.
