OlegP
Oct 31, 2018Apprentice
Broken QOS settings
I have Spectrum 200/10. Connected directly to the WAN port on the modem I usually get 200-218 download and around 10-13 upload.
With the XR500 router connected, the speedtest.net consistently g...
Netduma-Fraser
Oct 31, 2018NetDuma Partner
Thats very odd, usually with QoS completely disabled and still not achieving speeds thats not a DumaOS issue. I'm assuming these are all wired tests rather than wifi?
- OlegPOct 31, 2018Apprentice
Absolutely on wired. Its the only way.
- Netduma-FraserNov 01, 2018NetDuma PartnerYou mentioned in another topic you got a different modem and that resolved the speed issue. Is that correct? If so whats the other issue you're having?
- OlegPNov 02, 2018Apprentice
Different modem fixed the MAC address and half downstream bandwidth issue. Now it’s getting a goofy QOS bug.
