OlegP
Oct 31, 2018Apprentice
Broken QOS settings
I have Spectrum 200/10. Connected directly to the WAN port on the modem I usually get 200-218 download and around 10-13 upload.
With the XR500 router connected, the speedtest.net consistently g...
Netduma-Fraser
Nov 01, 2018NetDuma Partner
You mentioned in another topic you got a different modem and that resolved the speed issue. Is that correct? If so whats the other issue you're having?
OlegP
Nov 02, 2018Apprentice
Different modem fixed the MAC address and half downstream bandwidth issue. Now it’s getting a goofy QOS bug.
