Duelsy
Jan 07, 2020Follower
BT FTTC - Vigor 130 & XR500 no internet connection
Hi guys, first post unfortunately looking for help! Trying to setup a new system but having some issues, details below: Provider - BT Package - Halo 1 250MB FTTC Modem - DrayTek Vigor 130 Rout...
Netduma-Fraser
Jan 07, 2020NetDuma Partner
With BT, PPPoE (login) is sometimes required for an internet connection, do you know if you require this at all? If so you will need to input those details into Internet Setup before you can sustain a connection. Is there any way you can connect the XR500 to the Vigor without bridge mode or is that necessary?
