Duelsy
Jan 07, 2020Follower
BT FTTC - Vigor 130 & XR500 no internet connection
Hi guys, first post unfortunately looking for help! Trying to setup a new system but having some issues, details below: Provider - BT Package - Halo 1 250MB FTTC Modem - DrayTek Vigor 130 Rout...
MegaBrett
Jun 03, 2020Guide
Hi,
Did you resolve your issue as I am having a very similar problem with a different ISP Manx Telecom.
Modem connects fine over ADSL PPoA on its own.
Place Vigor in Bridge mode -> XR 500 in PPoE, failes with authentication error.
I've had to switch the XR500 into AP and pug it into my old Netgear router to use but not very happy with this currently.
- Netduma-FraserJun 03, 2020NetDuma PartnerWhat kind of error are you getting? Are you using Always Connect for PPPoE?
- MegaBrettJun 04, 2020Guide
Hi
I originally spotted an uthentication error in the logs, but there was so much information I didn't note down the detail.
I don't see it any more
My ISp is Manx Telecom. I connect over an ADSL2 line.
Previous router was a netgear DGN2200, no issues for many years.
PPoA & "always on".
Netgear router is in Always on & PPoE.
Draytek Vigor is bridged mode (MPOA).
Wasn't sure how (if) the encapsulation should be set.
- Bridged/routed IP LLC - (Default)
- Bridged /routed IP VC-Mux (IPoA)
- Bridged IPoE
Cheers for response.
- Netduma-FraserJun 04, 2020NetDuma PartnerAs the Vigor is now in bridge mode could you go through the Setup Wizard in Settings and see if it can detect and establish a connection properly through there please?
