Duelsy
Jan 07, 2020Follower
BT FTTC - Vigor 130 & XR500 no internet connection
Hi guys, first post unfortunately looking for help! Trying to setup a new system but having some issues, details below: Provider - BT Package - Halo 1 250MB FTTC Modem - DrayTek Vigor 130 Rout...
Netduma-Fraser
Jun 03, 2020NetDuma Partner
What kind of error are you getting? Are you using Always Connect for PPPoE?
MegaBrett
Jun 04, 2020Guide
Hi
I originally spotted an uthentication error in the logs, but there was so much information I didn't note down the detail.
I don't see it any more
My ISp is Manx Telecom. I connect over an ADSL2 line.
Previous router was a netgear DGN2200, no issues for many years.
PPoA & "always on".
Netgear router is in Always on & PPoE.
Draytek Vigor is bridged mode (MPOA).
Wasn't sure how (if) the encapsulation should be set.
- Bridged/routed IP LLC - (Default)
- Bridged /routed IP VC-Mux (IPoA)
- Bridged IPoE
Cheers for response.
- Netduma-FraserJun 04, 2020NetDuma PartnerAs the Vigor is now in bridge mode could you go through the Setup Wizard in Settings and see if it can detect and establish a connection properly through there please?
- MegaBrettJun 05, 2020GuideHi
With the vigor in Bridge mode,
The XR500 does not find the internet.
When I run the set up wizard it tells me it cant find the internet , suggests replacing the ethernet cable, retries then suggests logging in with the modems mac address
Then comes back suggesting it's the cable.
The cable is the same one that works when its plugged into my old router as an AP.- Netduma-FraserJun 09, 2020NetDuma PartnerTo test, could you try it without bridge mode please and see if you get a connection that way?
