P44EFC
Apr 16, 2020Apprentice
BT FTTP
Hi there, So in the next few weeks or longer depending on Lockdown rules i will be getting FTTP installed at my address, full fibre running 900 down and 220 up so i am excited to upgrade from the...
Apr 16, 2020Guru - Experienced User
Should work fine.
You would need to know if the new service comes with a a built in router already on the ONT or just a ONT only. ONT only is preferred with a RJ45 LAN port that the XR router can connect too. With those speeds, you can disable QoS on the XR router.
Netduma-Fraser
Apr 16, 2020NetDuma Partner
As above, the router should work fine with those speeds and provider.
