P44EFC
Apr 16, 2020Apprentice
BT FTTP
Hi there, So in the next few weeks or longer depending on Lockdown rules i will be getting FTTP installed at my address, full fibre running 900 down and 220 up so i am excited to upgrade from the...
Apr 16, 2020Guru - Experienced User
Should work fine.
You would need to know if the new service comes with a a built in router already on the ONT or just a ONT only. ONT only is preferred with a RJ45 LAN port that the XR router can connect too. With those speeds, you can disable QoS on the XR router.
P44EFC
Apr 17, 2020Apprentice
I have had a look closely and yes it is an ONT only with Lan port so that is good to know, disable QOS you say with those speeds ok i will do that, just use the other features like traffic prioritisation and the geo filter for the PS4 then?
- Netduma-FraserApr 21, 2020NetDuma PartnerIf you disable QoS completely then Traffic Prioritization won't work either but if you select never for Anti-Bufferbloat then you could continue to use Traffic Prio if you wish. Yes exactly.
