apr17
Jul 11, 2018Aspirant
BT Wholesale Service Information Page
Completely lost, hoping someone can direct me seeing as BT's telephone support is utterly useless.
Since moving house 2 days ago (this setup was working perfectly before that) I am unable to co...
apr17
Jul 17, 2018Aspirant
Apologies, I realised I missed the fact I am using a Draytek 130 Modem. Again this was working fine at the last house.
To clarify further, I purchased a new router and modem to test it today and I still run into the same issue. I have also manually updated the firmware on the new router and still get nothing. It says it's connected but still won't pass the speedtest. It also shows 0.004Mb downloads on the dashboard.
Again, switching back to the BT home hub rectifies all these issues and I get my 50MB connection instantly.
Netduma-Fraser
Jul 17, 2018NetDuma Partner
If you're getting it with another router as well then that means the ISP is blocking use of third party routers or the hub is setup to block it as a new connection. Put the XR500 in the hubs DMZ, does that resolve the issue?
