Zendorea
Dec 16, 2020Aspirant
Buffer-bloat QoS causing issues
Hello, I am finding that my XR500 Stops passing traffic randomly within every 12hr period. The work around for it is to either reboot the router or to Disable Buffer-Bloat QoS Feature all together. ...
Zendorea
Before I update to v2.3.2.66 two weeks ago and re enabled QoS/Buffer-bloat feature, Ran smooth for almost 6 Months.
I did some TSHOOTing this afternoon (Was tired of just rebooting the router); Disabled the QoS/Buffer-bloat feature and the Router started to pass traffic again with no issues. Confirmed my suspisons and looked at the log and found a Entry in the Router log that it applyed a QoS rule at the some timestamp my connection craped out.
I just updated my router to v2.3.2.108 and did a Full factory reset. Im going to see if this resolves the issue.
Netduma-Fraser
Dec 16, 2020NetDuma Partner
Okay keep us posted, I can't see it being QoS causing it, especially on pre-beta firmware but fingers crossed its sorted on beta.
- ZendoreaDec 24, 2020Aspirant
Since Upgrading to the Pre release version of the DunOS (As stated above) I have not had any issues.
- Netduma-FraserDec 24, 2020NetDuma PartnerThat's great to hear, thanks for the update. Happy holidays!
