Goliaths
May 15, 2024Follower
Bufferbloat, Lag, ETC... Nighthawk PRO XR1000
Hi All, I was hoping to get some assistance. I'm constantly dealing with issues of packet loss, and feel a notable delay in hit reg while FPS gaming. After a lot of experimentation and 8+ Spectrum Vi...
May 16, 2024Guru - Experienced User
What test results if you ethernet connect your test PC directly to the ISP modem or ONT?
How is the router configured for QoS and such? Where are the sliders positioned?
Test with QoS enabled and disabled to compare results.
Try testing with a different PC to compare results.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Try updating FW?
