egwok
May 12, 2021Tutor
Bug xr1000 pingheat map goes to default
My xr1000 is brand new and every once in a while the geo filter resets to default after I set it up is this normal ?
Netduma-Liam
May 13, 2021NetDuma Partner
Sorry to hear that!
How exactly does it reset? What is it resetting to? How is this indicated to you?
egwok
Jul 27, 2021Tutor
It use to reset the ping heat map polygon mode I had made but it’s fixed now but now I’m having a issue where I draw the polygon only around servers that are 20-35ish ping and it shows on the duma UI that I’m getting 20-35ish ping lobby but in call of duty Cold War in the ping meter I’m getting 50ish ping .why is this happening ? Plus it lags while playing .sometimes I showed the ping meter in COD Cold War 35ish ping meter but most times is 50ish ping meter and it’s a mess .please help I tried factory reset both router and modem with no luck .
- Netduma-FraserJul 27, 2021NetDuma PartnerThe in game ping includes things like processing delay - all games have it. The ping shown on the Geo-Filter is the ping direct to the server which is what you can control. The difference in ping there is about right. If you're not having a good experience then try to force a different server instead and see if it plays better.
- egwokJul 27, 2021TutorI’ve tried using different servers that are low ping it’s the same no matter what and I don’t have QOS enabled cause although me and my wife alone have a lot devices like iPad iPhone laptops.ect ... we are the only ones who live in my apartment and I pay for 300mbps d/L and 35 U/L .do u think I should use QOS? I send a pic of my ping heat map for COD COLDWAR also how I have my GEO filter setup
- Netduma-FraserJul 27, 2021NetDuma PartnerGo for servers that are higher ping, some people say that it gives you an advantage with lag compensation. Yes I would advise using QoS
- egwokJul 27, 2021TutorHere’s the ping heat map for COD COLDWAR
