Gimli
May 13, 2018Tutor
Bugs and Doubts
Hello when changing the language the router leaves the menu and can not return using the IP address of the router, always the error. There is no way to change the language, only deleting the data in ...
- May 15, 2018I've sent you a PM, please see if that resolves the language issue.
For Geo-Filter click the icon on the left of the magnifying glass and click on the map for Brazil.
Netduma-Fraser
May 14, 2018NetDuma Partner
I don't think I've encountered this before. What do you mean it leaves the menu? What error are you receiving?
Could you record a video of the issue you're having?
What firmware version are you on?
VPN Client is in Settings > Advanced Settings > VPN Client.
- GimliMay 15, 2018TutorWhen I switch from English to Portuguese language, it leaves an OS page and it is not possible to access the OS again through routerloguin.net.
Geo Filter has no option of placing Brazil.
I use the latest firmware: 2.2.1.10- Netduma-FraserMay 15, 2018NetDuma PartnerI've sent you a PM, please see if that resolves the language issue.
