Tiazeet5
Aug 13, 2020Follower
Buy a used product
Hey everyone, I am coming here because I need help. I bought an XR500 to someone else. The used product works perfectly but I can't set up it because the registration has already been by the pre...
DarrenM
Aug 18, 2020Sr. NETGEAR Moderator
You will have to contact support to see if they are able to help.
https://www.netgear.com/support/contact.aspx
DarrenM
